查看完整版本: [-- 焊接结构及工装 --]
中华焊接动力网旗下焊接社区 -> 国外焊接 -> 焊接结构及工装 [打印本页] 登录 -> 注册 -> 回复主题 -> 发表主题
tom2005 2007-04-13 22:02
焊接结构及工装
焊接结构welded structure/ welded construction
焊件weldment
焊接部件weld assembly
组装件built-up member
接头设计joint design
焊接应力welding stress
焊接瞬时应力transient welding stress
焊接残余应力welding residual stress
热应力thermal stress
收缩应力contraction stress
局部应力local stress
拘束应力constraint stress
固有应力inherent stress
固有应变区inherent strain zone
残余应力测定residual stress analysis
逐层切割法Sach’s method
X射线衍射法X-ray stress analysis
小孔释放法Mathar method
固有应变法inherent strain method
消除应力stress relieving
局部消除应力local stress relieving
应力重分布stress redistribution
退火消除应力stress relieving by annealing
温差拉伸消除应力low temperature stress relieving
机械拉伸消除应力mechanical stress relieving
应力松弛stress relaxation
焊接变形welding deformation
焊接残余变形welding residual deformation
局部变形local deformation
角变形angular distortion
自由变形free deformation
收缩变形contraction deformation
错边变形mismatching deformation
挠曲变形deflection deformation
波浪变形wave-like deformation
火焰矫正flame straightening
反变形backward deformation
焊接力学welding mechanics
断裂力学fracture mechanics
弹塑性断裂变形elasto-plastic fracture mechanics
线弹性断裂力学linear elastic fracture mechanics
延性断裂ductile fracture
脆性断裂brittle fracture
应力腐蚀开裂stress corrosion cracking
热应变脆化hot straining embrittlement
临界裂纹尺寸critical crack size
裂纹扩展速率crack propagation rate
裂纹张开位移(COD)crack opening displacement
拘束度restraint intensity
拘束系数restraint coefficient
应变速率strain rate
断裂韧度fracture toughness
应力强度因子stress intensity factor
临界应力强度因子critical stress intensity factors
罗伯逊止裂试验Robertson crack arrest test
ESSO试验ESSO test
双重拉伸试验doucle tension test
韦尔斯宽板拉伸试验Well’s wide plate test
帕瑞斯公式Paris formula
断裂分析图fracture analysis diagram
焊接车间welding shop
焊接工作间welding booth
焊接工位welding post/ welding station
焊工welder
电焊工manual arc welder
气焊工gas welder
焊接检验员weld inspector
焊工培训welders training
焊工模拟训练器trainer of synthetic weld
焊工考试welder qualification test
焊工合格证welder qualification/ welder qualified certification
钢板预处理steel plate pretreatment
喷沙sand blast
喷丸shot blast
矫正straighten
开坡口bevelling (of the edge)/ chanfering
装配assembly/ fitting
安装erect
刚性固定rigid fixing
装配焊接顺序sequence of fitting and welding
焊接工艺评定welding procedure qualification
焊接工艺规程welding procedure specification
焊接工艺试验welding procedure test
焊接工艺卡welding procedure card
工序operational sequence
焊接材料消耗定额welding consumables quota
焊接工时定额welder-hour quota
清渣slag removal
清根back gouging/ back chipping
锤击peening
返修次数number of rewelding
焊接工作台welding bench
装焊平台welding platen
电磁平台electromagnetic platen
焊接翻转机welding tilter
焊接变位机positioner
焊接滚轮架turning rolls
焊接操作机manpulator
焊工升降台welder’s lifting platform
焊接夹具welding jig/ fixture
磁力夹紧器magnetic jig
螺旋推撑器screw operated tensioning unit
焊丝盘绕机welding wire coiler
焊条压涂机welding electrode extrusion press
红外线加热器infra-red heater
干燥箱dryer
焊条保温筒thermostat for electrode
流量计flow meter
CO2预热器CO2 heater
CO2干燥器CO2 desiccator
焊接电缆welding cable
电缆夹头welding connector
地线earth lead
地线夹头earth clamp
焊接参数记录仪welding parameter recorder
焊缝检测规weld gauge
喷嘴通针tip cleaner
测温笔tempil stick
敲渣锤chipping hammer
焊接衬垫backing/ welding backing
保留垫板fusible backing/ permanent backing
临时垫板temporary backing
焊剂垫flux backing
惰性气体衬垫inert-gas backing
引弧板run-on tab/ end tab/ starting weld tab
引出板run-off tab/ end tab
定位板strong-back
加强勒stiffener
嵌条insert
套环ferrule
面罩helmet
滤光镜片filter glass/ welding glass
防护镜片cover glass/ plain glass
气焊眼镜welding goggles
焊接机器人welding robot
点焊机器人spot welding robot
弧焊机器人arc welding robot
切割机器人cutting robot
焊接机器人工作站welding robot station
机器人运动自由degree of free for robot
机器人工作空间robot working space
轨迹重复精度path repeatability
点位重复精度PTP repeatability
焊接专家系统welding expert system
焊接机器人示数welding robot play back
焊接图象识别pattern recognition for welding
焊接图象处理welding image processing
计算机辅助焊接工艺设计computer-aided welding process programming (CAWPP)
计算机辅助焊接结构设计computer-aided design for welding structure
张大发 2013-01-10 18:50
谢谢楼主
taoge 2013-04-17 08:55
查,什么东西!和帖子名称相符吗?
l121432711 2013-05-09 14:42
中英文对照吗?
查看完整版本: [-- 焊接结构及工装 --] [-- top --]
