查看完整版本: [-- 我所在的德国焊接培训中心 --]
中华焊接动力网旗下焊接社区 -> 国外焊接 -> 我所在的德国焊接培训中心 [打印本页] 登录 -> 注册 -> 回复主题 -> 发表主题
wangweld1971 2014-10-04 16:41
我所在的德国焊接培训中心
这是德国一家著名的工程机械焊接培训中心!
pineapple 2014-10-04 19:58
模拟焊接系统棒
kblll123 2014-10-04 21:10
不错,很干净啊
samlee 2014-10-04 21:29
锐耀制作 2014-10-04 23:10
用户被禁言,该主题自动屏蔽!
dives4shen 2014-10-05 08:36
其实最后那些图才是最重要的!!
xuht001 2014-10-05 08:38
看着确实不错啊
feitianyiliu 2014-10-05 09:01
[attachment=107485]
欢迎使用焊工资质识别软件 By 373435243@qq.com
输出日期:2014/10/5 9:05:01
焊工资质:ISO 9606-1 141 T BW FM4 S s3.6 D60 PH ss nb
焊工资格识别:---------------------
Code:
  ISO 9606-1
    Qualification testing of welders-Fusion welding Part 1:Steels
Welding process:
  TIG welding with solid filler material(wire/rod)
Product type:
  Tube
Type of weld:
  butt weld
Filler material group:
  Creep-resisting steels 3.75≤Cr≤12%
Examples of applicable standards:
  ISO 3580,ISO 21952,ISO 24598,ISO 17634
Filler material type:
  solid wire electrode-solid rod
Material thickness of test piece:
  3.6mm
Outside pipe diameter:
  60mm
Welding position:
  PH
Weld details:
  single side welding
  welding with no material backing
Examination and testing:
  Examination:
    The welding of test pieces shall be witnessed by the examiner or examining body.
    The testing  shall be verified by the examiner or examining body.
    The test pieces shall be marked with the identification of the examiner and the welder.
    Welding positions for all test pieces shall be marked on the test piece.
    The stop and restart areas shall be marked on the test piece.
    The 12 o'clock Welding positions shall also be marked on the test piece.
    The examiner or examining body may stop the test if the welding conditions are not correct or if it appears that the welder does not have the skill to fulfill the requirements.
  Test pieces:
    length ≥125mm,outside pipe diameter=60mm,t=3.6mm,2 parts per test,1 tests,the examination is 150mm.
  Welding conditions:
    The qualification test of welders shall follow a pWPS or WPS prepared in accordance with ISO 15609-1 or ISO 15609-2.
    The test piece shall have at least one stop and restart in the root run and in the capping run.
    When more than one process is used,then at least one stop and restart shall be carried out for each process,this include the root run and final run.
    The welder shall be allowed to remove minor imperfection by grinding ,except for the capping run for which only the stop and restart may be ground.The permission of the examiner or examining body shall be obtained.
    Any post-weld heat treatment required in the pWPS or WPS may be omitted at the discretion of the manufacturer.
  Test methods:
    All slag and spatters are removed.
    No grinding on the root and the face side of the weld.
    Stop and restart in the root run and in the capping run are identified.
    Profile and dimensions are correct.
    Visual testing according to ISO 17637.
      Excess weld metal(502),excessive convexity(503),excessive penetration(504) and undercut(501) shall be assessed in accordance with ISO 5817,quality level B;Others quality level C.
    And
    Radiographic testing according to ISO 17636 .
      Assessed in accordance with ISO 5817,quality level C.
    Or
    Bend test according to ISO 5173.
      A minimum of two root and two face bend test specimens shall be used,and the complete examination length shall be tested.
        One root transverse bend form 45°direction.
        One face transverse bend form 135°direction.
        One root transverse bend form 225°direction.
        One face transverse bend form 315°direction.
        At least one specimen shall be taken from a stop/start location.For this purpose,it is possible that a side-bend specimen can be substituted by a root-bend specimen.
        If A≥20%:
          The diameter of the former or the inner roller shall be 4t mm
          The bending angle 180°。
        If A<20%:
          The diameter of the former or the inner roller shall be 100*ts/A-ts mm
          The bending angle 180°.
      Specimens shall not reveal any discrete discontinuity ≥3 mm in any direction.
      Discontinuities appearing at the edges of a test specimen during testing shall be ignored in the evaluation unless there is evidence that cracking is due to incomplete penetration,slag or other discontinuity.
      The sum of the greatest discontinuities exceeding 1 mm but less than 3mm in any one bend specimens shall not exceed 10 mm.
    Or
    Fracture test according to ISO 9017.
      Four test specimens of equal width.
      Width of fracture test specimens ≥20mm.
      Taken form 45°& 135° & 225°& 315°direction.
覆盖范围:---------------------
welding process:
  141 & 142 & 143 & 145
Type of weld:
  butt weld in any type of joint except branch connections
  branch joints with an angle ≥60°
  fillet welds if a supplementary fillet weld test piece is welded with each process,filler material group and electrode covering/core.The test piece shall be at least 10mm thick or the thickness of the butt weld piece if the thickness is less,and completed using a single layer in the PB position. However only PA and PB fillet weld position are qualified by this test.
  FM1 & FM2 & FM3 & FM4
  S & M
  3 to 7.2mm
  ≥30mm
Product type:
  Tube & Plate
Welding position:
  PA & PE & PF
  H-L045 using upward welding if there is another test in welding position PC
Weld details:
  ss,nb & ss,mb & bs & ss,gb
  Note:The type of covering or flux cored wire used in the qualification test of welders for root run welding must be same with that used in the root run welding in production.
hanxiafugui 2014-10-05 14:00
敬请期待有更好的培训资料
小马驹 2014-10-05 15:25
长见识
高手都是谁 2014-10-05 19:33
还不错吧 看着
网事飘凌 2014-10-07 21:34
确实不错
aiyubuzai 2014-10-08 07:06
非常好啊,那个培训模拟器多少钱?这是哪家工程机械厂啊?
cyrain200 2014-10-08 14:02
长见识,楼主应该持续分享你的感受。。
焊管学徒 2014-10-08 16:43
和13楼同问?那个模拟机真爽!
pineapple 2014-10-08 20:03
上次在埃森展体现过一次
xjx199710 2014-10-09 13:56
什么地方,确实不错
weiqi 2014-10-09 15:20
zch217 2014-10-09 16:31
香港焊工同胞对“占中”行动如何看?
touming188 2014-10-11 09:56
看着很不错。
大树撒旦法 2014-10-14 11:17
非常不错
hedian123 2014-11-17 17:38
谢谢,分享了,条件是次要的,主要是怎么管理的
kent1968 2015-02-11 21:17
不错,见识了,谢谢分享!
查看完整版本: [-- 我所在的德国焊接培训中心 --] [-- top --]
