查看完整版本: [-- ASME 第九卷关于厚度覆盖范围的疑问 --]
中华焊接动力网旗下焊接社区 -> 工艺探讨及标准选用 -> ASME 第九卷关于厚度覆盖范围的疑问 [打印本页] 登录 -> 注册 -> 回复主题 -> 发表主题
木子鱼 2013-11-28 15:33
ASME 第九卷关于厚度覆盖范围的疑问
请见如下IX描述:
1)For full penetration single-sided welds without backing, where the measurement of penetration can be
     made by visual or mechanical means, requalification is required where the base metal thickness differs by 20%
     from that of the test coupon thickness when the test coupon  thickness is 1 in. (25 mm) and under, and 10% when the
     test coupon thickness is over 1 in. (25 mm). Where the measurement of penetration cannot be made, requalification
     is required where the base metal thickness differs by 10% from that of the test coupon when the test coupon
     thickness is 1 in. (25 mm) and under, and 5% when the test coupon thickness is over 1 in. (25 mm).
2)QW-403.6 The minimum base metal thickness qualified is the thickness of the test coupon T or 5⁄8 in. (16 mm),
      whichever is less. However, where T is less than 1⁄4 in. (6 mm), the minimum thickness qualified is 1⁄2T. This variable
      does not apply when a WPS is qualified with a PWHT above the upper transformation temperature or when an
      austenitic or P-No. 10H material is solution annealed after welding.
3)QW-403.2 The maximum thickness qualified is the thickness of the test coupon.
结合QW-451.1表,如果评定的材料为WCB,WPQR试板厚度为60,焊缝厚度为25,那么覆盖的范围:
母材应该是16-200,还是16-60啊!焊缝厚度覆盖的范围是不是0-50啊!
还有就是以上3条的描述,QW-403.2说母材评定的最大厚度为试块厚度,为啥1)条描述还多少倍,什么的!
william829 2013-11-28 16:27
楼主还没有明白标准要什么看。不同的焊接方法适用不同的条目的,不能总的一起来看的。
木子鱼 2013-11-28 16:49
你说的我不太明白。。。那么只从问题出发,你是怎么理解的,谢谢!
zsc19751013 2013-11-29 09:04
楼上: 对于ASME IX标准,里面的条款如果单独拿出来并不是适用于每一个PQR,不同的焊接方法查阅不同的QW-25X, 比如氩弧焊你要查QW-256,看那里面提到的提款是否是重要变素和非重要变素,如果你查一遍你就知道到底你所的条款是否适用了。
木子鱼 2013-11-29 09:45
谢谢斑竹的提醒,我的是SMAW,见QW-253,对于有冲击要求时,厚度覆盖范围按QW-403.6的附件限制执行,我的焊接工艺里面有要求冲击试验,所以母材的最低适用厚度为16mm,而对于QW-403.2的要求不适用于SMAW,所以最大范围为200,综合:16-200.
2)对于焊缝的厚度覆盖,参见QW-404.30,所以焊缝厚度覆盖的范围是0-50
我说的对吗?
木子鱼 2013-11-29 09:50
同时,这也帮我解决了NB/T47014关于冲击的厚度覆盖描述。。。现在吻合了
fengqiamg 2013-11-29 13:06
做工艺之前需要把什么是重要变素,非重要变素以及补加因素链接,不是所有的QW400之后的都适用于你采用的焊接方法[
木子鱼 2013-11-29 14:27
understand!同时问一下,QW-253中冲击要求,是特指低温冲击吗,如果单从翻译的角度,只是说冲击试验!
木子鱼 2013-11-29 14:28
这个我比较清楚,主要是没联想到表与描述之间的联系,谢谢
fengqiamg 2013-11-30 23:25
记住WPS和PQR的内容
查看完整版本: [-- ASME 第九卷关于厚度覆盖范围的疑问 --] [-- top --]
