查看完整版本: [-- Flying Saw Pipe Length computer pneumatic control devices --]
中华焊接动力网旗下焊接社区 -> 切割装备 -> Flying Saw Pipe Length computer pneumatic control devices [打印本页] 登录 -> 注册 -> 回复主题 -> 发表主题
didihay 2011-11-28 14:14
Flying Saw http://www.chinasrt.com
The invention relates to a fixed-length welded steel production cut-controlled flying saws computer cut to length steel pneumatic control device, characterized by: saw the car in the optical encoder device set to measure the speed and length of the pipe; settings are controllable pan The clamping device for the second error correction residual Length; in electrical circuits using computer control box, the utility model has the advantage of high accuracy, low price, easy installation, low failure rate, easy maintenance, suitable for the existing pneumatic flying fixed-length steel cutting saw improvements, get a higher economic efficiency.
查看完整版本: [-- Flying Saw Pipe Length computer pneumatic control devices --] [-- top --]
