查看完整版本: [-- 想提高英语专业水平 --]
中华焊接动力网旗下焊接社区 -> 国外焊接 -> 想提高英语专业水平 [打印本页] 登录 -> 注册 -> 回复主题 -> 发表主题
hanhan 2009-03-24 23:08
想提高英语专业水平
有没有能够提高焊接英语能力的资料或网站,长期系统的学习下
weiyankai 2009-04-30 19:08
学习英语最重要的就是语言环境,要经常跟别人交流,交流多了,你掌握的单词就多了,再学习其他的语法知识效果就好多了,你可以尝试着先提高自己口语,我之前找了许多家都是由于各种原因没学好,后来自己上网找了几个比较了一下,就是在家跟老外交流,学习英语,是小班授课,一个班4-8个人,小班课程开口机会很多,挺不错的,叫 乐知英语 ,各个级别的课程都有,是在线授课的形式,在家和老师就可以互动的交流,很方便,不用跑来跑去,老师质量非常的好,而且都是在国外的中外教,非常的地道,课时数很多,性价比很不错,而且每晚都有免费的试听课程可以体验,很透明,价格也挺不错的,有时间可以先上去免费试听一下啊,每晚的免费试听课程可以到这里看下,希望能对你有帮助哦 http://www.hiknow.com/sessionhall.html
z_x 2009-05-08 23:22
多看看现成的专业资料吧,中英文对照的资料最好,帮助很大
要是想练口语,就多跟老外交流吧
ivan_wong 2009-05-14 06:56
个人觉得,英语还是在应用中提高的很快,比如看工作资料,和和客户交流等等
qy2008 2009-06-05 15:36
More reading and talking with others more help to learn on web.
qianshixu 2009-06-10 20:19
Beginning
1. In this paper, we focus on the need for
2. This paper proceeds as follow.
3. The structure of the paper is as follows.
4. In this paper, we shall first briefly introduce fuzzy sets and related concepts
5. To begin with we will provide a brief background on the
Introduction
1. This will be followed by a description of the fuzzy nature of the problem and a detailed presentation of how the required membership functions are defined.
2. Details on xx and xx are discussed in later sections.
3. In the next section, after a statement of the basic problem, various situations involving possibility knowledge are investigated: first, an entirely possibility model is proposed; then the cases of a fuzzy service time with stochastic arrivals and non fuzzy service rule is studied; lastly, fuzzy service rule are considered.
Review
1. This review is followed by an introduction.
2. A brief summary of some of the relevant concepts in xxx and xxx is presented in Section 2.
3. In the next section, a brief review of the .... is given.
4. In the next section, a short review of ... is given with special regard to ...
5. Section 2 reviews relevant research related to xx.
6. Section 1.1 briefly surveys the motivation for a methodology of action, while 1.2 looks at the difficulties posed by the complexity of systems and outlines the need for development of possibility methods.
Body
1. Section 1 defines the notion of robustness, and argues for its importance.
2. Section 1 devoted to the basic aspects of the FLC decision making logic.
3. Section 2 gives the background of the problem which includes xxx
4. Section 2 discusses some problems with and approaches to, natural language understanding.
5. Section 2 explains how flexibility which often ... can be expressed in terms of fuzzy time window
6. Section 3 discusses the aspects of fuzzy set theory that are used in the ...
7. Section 3 describes the system itself in a general way, including the ….. and also discusses how to evaluate system performance.
8. Section 3 describes a new measure of xx.
9. Section 3 demonstrates the use of fuzzy possibility theory in the analysis of xx.
10. Section 3 is a fine description of fuzzy formulation of human decision.
11. Section 3, is developed to the modeling and processing of fuzzy decision rules
12. The main idea of the FLC is described in Section 3 while Section 4 describes the xx strategies.
13. Section 3 and 4 show experimental studies for verifying the proposed model.
14. Section 4 discusses a previous fuzzy set based approach to cost variance investigation.
15. Section 4 gives a specific example of xxx.
16. Section 4 is the experimental study to make a fuzzy model of memory process.
17. Section 4 contains a discussion of the implication of the results of Section 2 and 3.
18. Section 4 applies this fuzzy measure to the analysis of xx and illustrate its use on experimental data.
19. Section 5 presents the primary results of the paper: a fuzzy set model ..
20. Section 5 contains some conclusions plus some ideas for further work.
21. Section 6 illustrates the model with an example.
22. Various ways of justification and the reasons for their choice are discussed very briefly in Section 2.
23. In Section 2 are presented the block diagram expression of a whole model
of human DM system
24. In Section 2 we shall list a collection of basic assumptions which a ... scheme must satisfy.
25. In Section 2 of this paper, we present representation and uniqueness theorems for the fundamental measurement of fuzziness when the domain of discourse is order dense.
26. In Section 3, we describe the preliminary results of an empirical study
currently in progress to verify the measurement model and to construct membership functions.
27. In Section 5 is analyzed the inference process through the two kinds of inference experiments...
This Section
1. In this section, the characteristics and environment under which MRP is designed are described.
2. We will provide in this section basic terminologies and notations which are necessary for the understanding of subsequent results.
Next Section
2. The next section describes the mathematics that goes into the computer implementation of such fuzzy logic statements.
3. However, it is cumbersome for this purpose and in practical applications the formulae were rearranged and simplified as discussed in the next section.
4. The three components will be described in the next two section, and an example of xx analysis of a computer information system will then illustrate their use.
5. We can interpret the results of Experiments I and II as in the following sections.
6. The next section summarizes the method in a from that is useful for arguments based on xx
Summary
1. This paper concludes with a discussion of future research consideration in section 5.
2. Section 5 summarizes the results of this investigation.
3. Section 5 gives the conclusions and future directions of research.
4. Section 7 provides a summary and a discussion of some extensions of the paper.
5. Finally, conclusions and future work are summarized
6. The basic questions posed above are then discussed and conclusions are drawn.
7. Section 7 is the conclusion of the paper.
Chapter 0. Abstract
1. A basic problem in the design of xx is presented by the choice of a xx rate for the measurement of experimental variables.
2. This paper examines a new measure of xx in xx based on fuzzy mathematics which overcomes the difficulties found in other xx measures.
3. This paper describes a system for the analysis of the xx.
4. The method involves the construction of xx from fuzzy relations.
5. The procedure is useful in analyzing how groups reach a decision.
6. The technique used is to employ a newly developed and versatile xx algorithm.
7. The usefulness of xx is also considered.
8. A brief methodology used in xx is discussed.
9. The analysis is useful in xx and xx problem.
10. A model is developed for a xx analysis using fuzzy matrices.
krieggott 2009-07-20 11:42
shileilanqiu 2009-08-23 09:10
好东西啊,谢谢分享
twtdqadwr 2011-10-24 17:31
End-crater cavity
paton 2012-02-22 12:23
AWS和TWI的网站上提供了很多有用的链接,另外米国还有个焊接论坛weldingweb里面挺有意思,除了工业焊接,还有不少在自家车库里DIY自己的车,船甚至铁门时遇到问题的
422910839 2013-12-09 16:06
还是得有这个交流环境
查看完整版本: [-- 想提高英语专业水平 --] [-- top --]
