kangruoyu001 |
2009-03-04 10:36 |
为初学者提供方便
kangruoyu001@126.com焊接方法与几种焊材的中英文对照 自己在工作中总结出了几种焊接方法和焊材的英文名称,看大家是否用得上,以供出学者参考对照。 MIG ---Metal Inert Gas arc welding ---熔化极惰性气体保护电弧焊 MAG ---Metal Active Gas arc welding---熔化极活性气体保护电弧焊 TIG ---Tungsten Inert Gas Welding---钨极惰性气体保护焊 SAW ——Submerged Arc Welding——埋弧焊 FCAW ——flux cored arc welding——药芯焊丝电弧焊 FCW-G ——gas-shielded flux cored arc welding——气保护药芯焊丝电弧焊 FCW-S——self-shielded flux cored arc welding——自保护药芯焊丝电弧焊 GMAW——gas metal arc welding——熔化极气体保护电弧焊 GTAW——gas tungsten arc welding——钨极气体保护电弧焊 焊材与焊接常用词汇: 焊丝:welding wire. Welding rod 实心焊丝:solid wire 镀铜焊丝:copper-plating welding wire 或copper-coating welding wire 药芯焊丝:flux-cored wire 填充焊丝:filler wire 焊条:electrode/ covered electrode 酸性焊条:acid electrode 高钛型焊条:high titania (type) electrode 钛钙型焊条:lime titania type electrode 钛铁矿形焊条:ilmenite type electrode 氧化铁型焊条:iron oxide type electrode/ high iron oxide type electrode 高纤维素型焊条:high cellulose (type) electrode 石墨型焊条:graphite type electrode 碱性焊条:basic electrode/ lime type covered electrode 低氢型焊条:low hydrogen type electrode 高韧性超低氢焊条:high toughness super low hydrogen electrode 奥氏体焊条:austenitic electrode 铁素体焊条:ferritic electrode 不锈钢焊条:stainless steel electrode 珠光体耐热钢焊条:pearlitic heat resistant steel electrode 低温钢焊条:low temperature steel electrode/ steel electrode for low temperature 铝合金焊条:aluminum alloy arc welding electrode 铜合金焊条:copper-alloy arc welding electrode 铜芯铸铁焊条:cast iron electrode with steel core 纯镍铸铁焊条:pure nickel cast iron electrode 球墨铸铁焊条:electrode for welding spheroidal graphite cast iron 铸芯焊条:electrode with cast core wire 镍基合金焊条:nickel base alloy covered electrode 渗铝钢焊条:alumetized steel electrode 高效率焊条:high efficiency electrode 铁粉焊条:iron powder electrode 重力焊条:gravity electrode 立向下焊条:electrode for vertical down position welding 水下焊条:underwater welding electrode 耐海水腐蚀焊条:seawater corrosion resistant steel electrode 堆焊焊条:surfacing electrode 耐磨堆焊焊条:hardfacing electrode 钴基合金堆焊焊条:cobalt base alloy surfacing electrode 碳化钨堆焊焊条:tungsten carbide surfacing electrode 高锰钢堆焊焊条:high manganese steel surfacing electrode 管状焊条:flux-cored electrode |
