查看完整版本: [-- 5000積分征AWS D1.2/D1.2M 2014编译 --]
中华焊接动力网旗下焊接社区 -> 求助专版 -> 5000積分征AWS D1.2/D1.2M 2014编译 [打印本页] 登录 -> 注册 -> 回复主题 -> 发表主题
mechen 2016-10-01 15:03
原始word电子文件由个人提供(已排版好),希征的两位具焊接实务经验会员彼此协同作业完成此标准。于交稿完成后,领帖者除可平分悬赏积分外,另外加送一套WPS产生软件。
领帖期限:10/07/2016
有意领帖者请留下您的信箱或跟个人联系(mechen002991@gmail.com)
P.S. 这是在本网初啼声,看看本网是否值得个人留恋发帖
mechen 2016-10-01 15:09
Weldassistant Pro 7.4.0.1536
<a href="http://avxhome.in/software/Weldassistant.Pro.7.4.0.1536.html#" "="" style="box-sizing: border-box; color: rgb(165, 42, 42); word-wrap: break-word; background-color: transparent;">[attachment=120533]
Weldassistant Pro 7.4.0.1536 | 123.8 Mb
Generate, print and use a WPS (Welding Procedure Specification) in no time at all. Perform the associated welding cost calculation and welding cost optimisation. The result can be actioned in the daily routine immediately. Whether it's in the workshop, office or on building sites - weldassistant® can be used without any additional resources. You have a constant overview of you welders' qualifications and are able to initiate any necessary measures immediately.
Generate welding procedure specifications (WPS) including WPS Template
The comprehensive database and process dependant entry system means you arrive at the welding procedure specification (WPS) quickly and easily.
Managing Welding Procedure Qualification Records (WPQR / PQR)
Quickly find the needed WPQR (PQR) Welding Procedure Qualification Record and keep track of the status.
Welder qualification and Welder certification management (e.g. EN 287-1; EN ISO 9606)
Keep a constant eye on your welder qualification and welders certification. The current status of a welder's certification can be seen at a glance on the "traffic light" symbol.
Welding cost calculation
Keep welding costs under control and calculate to meet market requirements.
Compare any calculations with a view to optimizing your weld cost.
Plug-in concept
Following manufacturer plug-ins provide you with welding process data sheets or product information.
- ESAB Welding and Cutting (OK-Handbook)
- Safra (Aluminium + Copper filler metal)
- Linde Gas
- Air Liquide
- PanGas
- Praxair
- Wolfram Industrie
Philosophy
- Don't type - just click
- fast, straightforward, compact and any amount of data
- polish off simple tasks
- the fast track to welding solutions, welding procedure and more
- the WPS program which generates resources
Use the weldassistant software because…
your work, as supervisor or the person accountable, has to be fast and efficient
you place emphasis on proven, practical solutions
you want to concentrate more on the core assignments of your work
you want to gain more time for actual project work by deploying welding procedure software
you want to fulfill the quality requirements of the EN ISO 3834, EN 1090,EN 15614 etc.
All PRO Editions include:
All BASIC features
Welder qualification administration
Operator qualification administration
Welder Certificates preparation (e.g. EN 287-1; ISO 9606)
Operator Certificates preparation (e.g. EN1418; ISO 14732)
Weld cost calculation
weldassistant PRO
All PRO features
ISO - WPS
ASME - WPS
qianyinbian2008 2016-10-02 10:13
我来应征
394362 2016-10-02 10:36
我记得这个软件压缩包里的 nfo文件上的注册码注册无效来着
mechen 2016-10-02 14:58
親測試有效的 (有註冊碼)
394362 2016-10-02 16:07
Key:FLAS-1707-WEDD
无效
6.X版本的我也有 ,无效
5.X的有keygen,但是没程序
popjoy 2016-10-04 09:24
此软件有效,不错的!
mechen 2016-10-04 10:06
您應該是在ASME疤下載的吧!在ASME啞巴那養是我發的(不過已終止),Self-reliance/healer/Red-bean都拜表著我,為求積分發起編譯作業方會如此,部過個人很是奇怪您為何不參與呢?能達到此帖功能,那ASME8女神即轉換為焊接女神,個人翻譯過之作品,您應當知,焊接這一門對雖為女流的我應算是研究級(學術/研發)的人了。加入編譯作業吧,ASME叭就不去了,或許我真應停到ASME啞巴那邊,這樣才能達到目的的,
   ASME 有的,個人絕對都有,而那邊沒了個人都的是。讓我來此網發展吧。不過說也奇怪,本站管理員是否存在呢,還是王八羔子不管他是什怪物,他走他的吊我走我的路,難怪本往會比不上ASME8,ASME8管理員Es會針對指名其交代/評論..鄧做出回應的,在分享之料時往往有好幾個分身的,個人知道(已確認過的)就有6個不暱稱。
  拜您與上列已報名會共同達成個人心願。同時在未達成此目標前也不在中國任何論壇在做出分享了,大家都太自私了,光指向等現成的。說真的,個人往後將如是做,不在作發表而是以翻譯來換取以編譯好的任何標準/規範。看來您英也只是一個等結果的人,不然證實給個人看看。
DGDGUYY 2016-10-06 13:03
台湾?香港?
ibelieve 2016-10-09 10:48
对您提到的那个软件很感兴趣!有试用版吗?
mechen 2016-10-11 19:41
這可是含註冊碼的正式版
mechen 2016-10-11 19:43
您是否是"olvo"
mechen 2016-10-12 07:21
深為論壇版主,您不想為論壇盡點力嗎?  鄉心您聽過ASME吧女神吧!只是在該論壇改了暱稱(Red-bean/ healer/ Self-reliance)罷了,我真的很想知道傳業焊接論壇的實力到何境界;先前有兩位會員聯繫過,一位經思量後放棄了,另一位所翻出來的虛個人逐條去修正,所以亦已告知該熱心會員如質量是如此那就終止編譯,但對他的承諾一分不減。
若您有興趣,且自信在所編一的質量上能達到水準之上(真實反映條文經文且文詞用法上不僵化(口語化)),那就讓個人看看焊接動力網的實力。您應可寄將此番應與論壇管理員(總版主)。
個人可追加一套全整的AWS標準(更新至02/10/2016)給領帖者,但先決條件是能讓我接受編譯的成果,我不想再去逐條修正不良的翻譯結過,如過真是那是是不會兌現承諾的。另,往後個人所編譯的中英對照版/專業叢書/資料亦以本論壇為主要分享對象。
個人的分享能力,您可到ASME吧和馬后炮(暱稱帥妹mechen-馬哥取的),況個人喜歡舉辦論壇互祝活動,不管是以積分或是會員要RMB多事會答應的,此求諈中的目的,給出優質的中英對照版給中國工程師們自我提升。
個人之所以會到此發起此編譯活動,說穿了還是想試一下焊接動力往的實力在哪裡?如願意領領可連繫(mechen002991@gmail,com)
donghaiyu 2016-10-12 19:47
这个确实还是有难度的,铝焊接规范本身就很多人不熟悉,要是钢结构的话还可以挑战一下
mechen 2016-10-13 16:29
這僅跟焊接知識(學理)是否通達有關而已,無關於各類材質。且AWS的D1.2與D1.1的排版/用語方式相近,沒怎大不了的,所以焊接動力網是沒動力的,跟我到其他論壇甚至對您會更好。
mechen 2016-11-23 10:02
您是具有頗高焊接專業學術背景的人,時不須居泥於客套上的話做...,既然您說對鋁結構不孰悉,那D1.5可否?
個人之所以努力編譯一些常用標準,也是想中國工程們有一個較佳質量的範本可用時參照,絕非屬於個人所專有,在現今中國知識分子中肯付出時間來提供中國整體焊接實力者寥寥可數,絕非是要RMB,但答應他們的條件是對其所翻譯的質量需負責,否則難以對面,也因此...沒人了,我是一個出生台灣的湖北人,著實看不慣那些所謂的的專業出版社所出版的中文版(這都是中國論壇中會員得心聲)。
既然身負專業學經歷理當多為中國的專業學術做出貢獻。
個人曾在ASME八開過焊接講堂,希藉此提升會員們的基本焊接理念,不過反應並不是很熱絡,所以在發布十來篇文章後就予以停止,或許在此論壇更應該如此做,由簡入繁逐步闡述所有相關的焊接冶金/材料..等應具備的常識。
如您還願意協助D1.5煩請與個人聯繫;而個人目前也針對先前開了振華玩笑的D1.1-2015全面校稿修訂中,畢竟不管是宏華還是振華其實剁是一樣的,只是宏華起始於振華較早期版本,往後就僅就實際需求選擇性進行內容上的修訂,因畢竟它是拿步道翻譯費用的,所以嫌棄鴻華就等於在唾棄振華的不堪。
dancc889 2017-09-14 22:08
我正在到处找他的中文版本了,楼主有的话,给我发一份吧,谢谢!
danchuchen@163.com
查看完整版本: [-- 5000積分征AWS D1.2/D1.2M 2014编译 --] [-- top --]
