  • 530阅读
  • 0回复
寻可移动的热处理设备 [复制链接]
2595
8603
753
50
只看楼主 倒序阅读 使用道具 楼主  发表于: 2016-11-21
各位老师,我以前的领导需要发往中东石油钻井平台的热处理设备,具体要求如下:
  Heat Treatment Equipment Set
i. Heat treatment equipment suitable for pre-heat and post-heat treatment of pipe-work & pressure vessels in accordance with specification ANSI B31.3.
ii. The equipment should be suitable for Arabian Gulf service and should take into account humidity, high ambient temperatures and the offshore environment.
iii. The equipment shall be of the Manning type 12 channel 70kva twin programmer / recorder, heat treatment center power unit, 12 point recorders and 2 No. automatic programme controllers. Provided complete with cables, splitters, ceramic pads, finger elements, magnetic fixing pads, thermal insulation, thermocouples, attachment unit, digital hand held thermometer and all the necessary ancillaries to facilitate heat treatment in accordance with ANSI B31.3.
iv. Post-heat wrap-arounds shall also be supplied for pipe diameters: 6” – 12” inclusive.
v. Equipment to be operated from ship’s power supply and which must comply with QP requirements for plant & equipment. Separate primary power extension cable 100m long supplied complete with plugs & cable storage reel.
Unit to be stored and transported in dedicated custom built container.
    麻烦如果知道这种设备的信息或者销售这种设备的厂家留下联系方式,或者和我联系,电话18764261990.张锟。谢谢。
